The General group contains the following information about the benchmark and the test:
Attribute |
Type |
Description |
ID |
string |
Specifies a unique ID for the test result reported in a particular inventory file |
Profile |
string |
Optional. Specifies the ID of the profile applied during the benchmark application |
Start time |
string |
Specifies the time when the benchmark application or compliance check started |
End time |
string |
Specifies when the check ended. Both start and end times are given as strings in the format used for XCCDF files |
Benchmark Ref |
int64 |
Specifies a reference (filename or link) to the used XCCDF file |
Title |
string |
Optional |
Remark |
string |
Optional |
Organization |
string |
Optional. Specifies the organization that is responsible for the results |
Organization_2, Organization_3... |
string |
Optional. Specifies additional organizations. If the additional organizations are hierarchical then they must appear in high-to-low order |
