Configuring Asset Management › Collection Modules › Inventory Template Modules › View or Modify Existing Inventory Templates
You can modify a template to add, edit, or remove groups and attributes.
To view or modify a template
- Navigate to the Control Panel, Configuration, Collection Modules, Inventory Template Modules folder.
The existing templates are displayed in the right pane.
- Double-click the template you want to view or edit.
The Properties dialog for the selected template appears.
- Click Template Editor.
The Template Editor dialog appears displaying the group and attributes defined in the template.
- Click Edit Group or Edit Attribute to modify the groups or attributes of the template respectively, and click OK.
The changes to the template module are saved.
