The binary "amusernt.exe" is used with the additional DLLs. Using the basic inventory file list along with this additional binary will make this inventory binary work. The command line to call this binary is as follows:
amusernt.ext invdata.inv
Based on the above information, the ini file of this additional inventory collection module is created. The file is named as addmod.ini in this example.
See the content of the file below to notice that you need to change the following options in the ini file based on your requirements:
Note: If the value in the AdditionalModules field is 2, the second set of module information would be as follows:
The content of the file is as follows:
[General]
OutputFolder=.\
OutputFile=
Origin=CA NRI (User Account Scan)
Trustlevel=5
TrustlevelRestrictedUser=3
KeepHostkey=Yes
[Inventory]
Method=1
ScanRestrictedUser=1
AdditionalModules=1
Module1Binary=amusersnt.exe
Module1Commandline=.\users.inv
Module1Outputfile=.\users.inv
Module1cleanup=.\users.inv
TemplateModules=0
[Software]
Method=1
