Before uninstalling the asset management agent, you must call the script UAMhmcDeconfig (usually under the $CA_ITRM_BASEDIR/Agent/AM/scripts path) to undo the configuration on the HMC. If this is not done before the uninstallation, the “uamuser” user is left in the HMC computer. While on the agent computer, the SSH key for this uamuser is left in $ROOT_HOME/.ssh/uamkey.
