The Asset Collector CAF plug-in is automatically installed with a scalability server on a Windows platform.
However, the asset collector plug-in is not enabled or running by default.
To enable the plug-in you have to run the following command:
caf enable assetcollector
The plug-in is then visible in a caf status.
Start the asset collector plug-in with the following command:
caf start assetcollector
