Previous Topic: CA Asset Converter for Microsoft SCCMNext Topic: Task Properties
Create a CA Asset Converter for Microsoft SCCM Engine Task
To configure the CA Asset Converter for Microsoft SCCM, you need to first create an engine task.
Note: A CA Asset Converter for Microsoft SCCM engine task cannot be assigned to an engine that is running on the same computer as the Microsoft SCCM site server from which it is meant to extract data.
To create a CA Asset Converter for Microsoft SCCM engine task
  1. Open the DSM Explorer and navigate to Control Panel, Engines, Engine Tasks.
  2. Select New from the Tasks area of the information pane.
    The New Task Wizard for engine tasks appears.
  3. Select CA Asset Converter for Microsoft SCCM from the Task type drop-down list, as shown in the following illustration:
    Create New Task wizard page specifying the type of task to be selected
  4. Click Next.
    The remaining screens are identical to the Properties dialog of an existing CA Asset Converter for Microsoft SCCM task and are described in the next section.
