Previous Topic: Agent BridgeNext Topic: Limitations
UUID Generator for Agent Bridge
A UUID generator allows Agent Bridge to generate an agent UUID for a legacy agent if one has not been reported. Additionally, a new configuration policy has been added to control the UUID generation behavior.
Note: You should always use the latest agents possible for your operating environment. To check the certification status of a legacy agent, see the appropriate Compatibility Matrix available on the CA Support Online web site, http://support.ca.com.
