Symptom:
I registered a Unicenter Asset Management 3.2 agent first, then immediately registered a Unicenter Software Delivery 4.0 agent. After a few minutes I saw two agents displayed in the DSM Explorer with the same name, one for Unicenter Asset Management and one for Unicenter Software Delivery.
Solution:
With the UUID generator enabled, the Unicenter Asset Management agent has generated a host UUID via Agent Bridge, but the Unicenter Software Delivery agent has received a host UUID from the agent computer itself. If both agents are registered within a very short time frame, then there is the possibility that duplicate agent names would be generated, one for Unicenter Asset Management and one for Unicenter Software Delivery.
In this situation, you have to manually remove the Unicenter Asset Management agent by deleting it from DSM Explorer. To avoid this problem from happening again, follow these registration rules:
To register legacy agents, some of which may not report their own UUIDs
In general, the majority of Unicenter Asset Management 4.0 agents and Unicenter Software Delivery 4.0 agents report host UUIDs when registering with the server.
