Symptom:
I cannot collect from network drives.
Solution:
By default the asset collector runs as the Local System account user. You will not have access to the network drives of your computer. You have to configure the Asset collector CAF plugin to run as a different user.
To enable the Asset Collector to collect from network drives
caf setprop assetcollector setcreds 1
caf setcreds assetcollector user <username> password <password>
caf stop assetcollector caf start assetcollector
To reverse this configuration, use the following command:
caf setcreds assetcollector user “” password “”
