Previous Topic: cacertutil import—Import a CertificateNext Topic: invSign—Sign, Verify, or Unsign an Inventory File
cacertutil import—Import the Public Key
The cacertutil import command imports the public key on the Asset Collector server to the Client Automation comstore.
cacertutil import -i :filename -t:tag -it:certificatetype
-i:filename
Specify the filename of the certificate to be imported.
important parameters:
-it:type
Specify the type of certificate to be imported. Valid options are X509V3 or PKCS#12.
Default is PKCS#12.
-t:tag
Specify a tag name.
Note: For more information about cacertutil commands, see the Command Line Reference Guide.
Example: Import the Public Key
cacertutil import -i:C:\AssetCollectorCert.der -t:AssetCollector -it:x509v3
