Customizing Asset Management › Asset Collector › Asset Collector Configuration › Configure the Asset Collector
You can customize, or configure, the Asset Collector for your specific environment.
To configure the Asset Collector
- From the DSM Explorer, navigate to the Control Panel, Configuration, Configuration Policy node.
- Right click on Configuration Policy and select New Policy.
The New Configuration Policy dialog appears.
- Enter a Name and Description and click OK.
The new configuration policy appears in the tree view.
- Click on the new configuration policy node you have just created to expand it.
- Click on DSM, Scalability Server, Asset Collector.
All of the Asset Collector policies appear on the Asset Collector pane.
- Double-click the appropriate setting, for example, Collection Folders.
The Setting Properties dialog appears.
- Set the value for the setting.
- Repeat Steps 3 and 4 as necessary.
- Click OK.
- Right-click on the policy node and select Seal from the menu.
- Drag-and-drop the policy onto the Scalability Server in the All Computers folder.
This applies the policy to the Scalability Server you want to configure with this policy.
The Asset Collector is configured for your environment.
Note: Before you can modify a policy, you must unseal it. For more information, see the Configuration Policy section of the DSM Explorer Help.
More information:
Origin and Trust Level
