The following table includes the valid types and subtypes that you can specify for the attributes:
Note: The subtypes determine how a value is displayed in the GUI.
Type |
Subtype |
Description |
Boolean |
Boolean values can be displayed based on the following subtypes: |
TrueFalse |
True or False |
YesNo |
Yes or No |
OnOff |
On or Off |
SupportedUnsupported |
Supported or Not Supported |
ActiveNotactive |
Active or Not Active |
OkError |
OK or Error |
PresentNotpresent |
Present or Not Present |
int32 & int64 |
Numerical values can be displayed based on the following subtypes: |
separation |
Thousands separated, that is, 1,000,000 |
normal |
No separation |
K |
Number is divided by 1024 before display |
M |
Number is divided by 1024^2 before display |
G |
Number is divided by 1024^3 before display |
T |
Number is divided by 1024^4 before display |
kilo |
Divided by 1000 before display |
mega |
Divided by 1e6 before display |
giga |
Divided by 1e9 before display |
milli |
Multiplied by 1e3 before display |
micro |
Multiplied by 1e6 before display |
nano |
Multiplied by 1e9 before display |
hex |
Numbers shown as hex |
time |
Displayed as a date-time |
timeInterval |
Displayed as a duration |
bytes |
GUI decides to display as KB, MB, GB or TB |
Float |
Float values can be displayed based on the following subtypes: |
Auto |
Auto format |
placesXX |
Show to XX decimal places |
String |
No subtypes for string |
