Previous Topic: Certificate used for Integrity Checking of IntellisigsNext Topic: Set Default Timeout for Intellisigs
Detect Software on a 64-bit OS Using Both 32-bit and 64-bit Registry
You can specify the architecture value of a registry when creating custom traditional signatures in DSM Explorer for both registry and file entries. The specified value checks that a binary is built for the specified Windows architecture.
  1. Navigate to DSM Explorer, Software, Definitions, software category, Release of software category, Properties, Recognition, Advanced, Registry.
  2. Select one of the following values in the Architecture drop-down box for a 64-bit OS:
    32
    Triggers a search in the 32-bit registry hives.
    64
    Triggers a search in the 64-bit registry hives.
Note: If you change the OS group type to UNIX, the Architecture drop-down box is disabled.
