Only AM remote agents can collect virtual host inventory data. You must know the AM remote agents and virtual hosts in your environment so that you can decide the virtual hosts you want to assign to each AM remote agent. For example, you have nine virtual hosts and want to assign three hosts per AM remote agent. You can view all the AM remote agents and hosts available and can decide the hosts that you want to assign to each AM remote agent.
The Select Target dialog opens.
The Query Designer dialog opens.
The Select Field dialog opens.
Note: Alternatively, you can use the Assets with the AM Remote Agent Component query to view all remote AM agents.
Note: If you do not see the server name in the list, click <more..> at the end of the list. Increase the Result limit to a higher number if you still do not see the server name in the Search possible value dialog.
You are returned to the Query Designer dialog.
The query returns the list of remote agents or virtual hosts that are based on your criteria.
