Previous Topic: Viewing Results in the GUINext Topic: Exporting Results
Preview and Print Results
Result sets can be previewed in HTML view and also printed. The print result is based on the HTML generation, which can be customized by the user. Customization includes table generation properties, sorting and more. Furthermore, the user can access and modify the Cascading Style Sheet, which defines most default formatting options for the HTML generation.
Note: You need to run the report to preview or print its result.
To preview and print the results, right-click the result and select Print. The HTML report is displayed as a preview in a separate window. This window has the following buttons.
Print
Opens the Microsoft Windows Print dialog.
Page Setup
Opens the Microsoft Windows Page Setup dialog for specifying the page properties.
Options
Gives access to any available layout and customization option for the result.
Close
Closes the current window.
