You can also export report templates from one domain to another domain in an enterprise to reuse the report templates.
To export reports from the selected folder (including sub folders)
The Export Report Template dialog appears.
The report templates available in the selected folder and all its subfolders are exported to the destination folder.
Note: You can also export a particular report to a file, by right-clicking the report and selecting Export, Report Definition.
