Previous Topic: Working with the ReporterNext Topic: Run a Report
Create New Report Template
Report templates contain the definitions for a report. Once created, you can either run these reports or schedule it to run at specific times.
To create a new report template
  1. Right-click the appropriate folder under the Report Templates folder and select New Report Template.
    The Report Template Type dialog appears.
  2. Select the type of the report template and click OK.
    Based on the selected report type, the New report type dialog appears.
    Note: For more information about the Report Template Type dialog and the New report type dialog, see the DSM Reporter Help.
