Architecture › Enterprise Manager
Enterprise Manager
The enterprise manager lets you synchronize and concentrate data from all of its connected domains. In distributed installations, it lets the headquarters maintain an overview of the subsidiaries. The enterprise manager helps you perform the following tasks:
- Access multiple domains and their data from the enterprise manager. For example, you can access the inventory, user information, jobs, and alarm definitions of all the connected domains.
- Perform consolidated actions that apply to either selected or all of the connected domains. For example, you can configure policies that you want to apply on selected or all the domains.
- Prepare reports that include the data from the domain managers that are connected to the enterprise manager.
Note: You can have only one enterprise manager in an environment.
