Use the Directory Synchronization Job to synchronize two directories on an asset. Synchronization involves comparing the contents of the target directory and the source directory, and making the content of the former identical to the latter.
Note: This job can be linked only to the computer assets and is applicable only for Windows agents.
In Step 3 of the New Job wizard, specify the directories:
Indicates the directory to be compared against (the image).
Indicates the directory to be examined for differences (reflection of the image).
Note: The use of UNC path is supported. Syntax: \\servername\sharename
In Step 4 of the New Job wizard, specify the following:
Example: Printer File Synchronization
This is an example of how to update the printer files of users that are on the local hard disk of the users. To make it easier, you need to update only, say, N:\PRINTERS with the latest printer files. You can then use directory synchronization to equate the directories C:\WINDOWS\PRINTERS and N:\PRINTERS. The printer files located on the hard disk are now made equal to the printer files on the network drive N. The directory is thereafter examined for differences each time the computer starts on the network.
Source: N:\PRINTERS
Target: C:\WINDOWS\PRINTERS
Enabled: Include Subdirectories; Delete unknown files; Ignore file attributes on compare; Ignore file attributes on copy.
Example: Portable Computer File Update
If there are portable computers on your network, you can synchronize a subdirectory on the portable computer’s hard disk with a personal network drive on the server. This permits automatic transfer to the network of portable computer files that were created while the portable computer was not connected to the network.
The Directory Synchronization Job ensures absolute conformity between two directories. It ensures that the attributes are also equal. Files on the target that are not found on the source will be deleted, if so specified. Directories not found on the target will be created.
In some cases, you do not want all files and subdirectories in a directory to be synchronized. (For example, in an Agent Software directory, you do not want the PROTOCOL.INI and the HOST files to be equal throughout your network.) In this case, you should specify the files and directories, which should not be synchronized.
Example: File Exclusion
This is an example of how to exclude files from synchronization. Assume that the local C:\PW directory is synchronized with a default network directory F:\PWDEFAUL. As a system manager, you know that the PROTOCOL.ini file and all the *.TPL files of that directory must be excluded from synchronization, because those files contain unique values for each individual computer. (The directory BAK is also excluded).
Source: F:\PWDEFAUL
Target: C:\PW
Enabled: Include Subdirectories; Delete Files on Target if Unknown on Source.
Specified: Files not to be synchronized: *.TPL, PROTOCOL.INI, (DIR) BAK
