You can configure the User Template inventory module or any other user-defined module to specify the attributes you want to collect and configure when to prompt the user for input.
To configure the User Template inventory module
The existing templates in the domain are displayed.
The Properties for User Template dialog appears.
The Template Editor dialog appears displaying the attributes being collected in a tree structure.
Note: Once the values for these attributes are collected, the tree structure is replicated under the Inventory, Additional folder of the user.
The Edit attribute dialog appears.
When the agent runs next time it prompts the user for input.
Note: For more information about creating, viewing and modifying the template modules, see the Asset Management section of the DSM Explorer Help.
