Jobs are executed in the same order in which it was created. However, you can change this order if the execution of one job depends on the execution of another.
Note: You can do this only at the group and asset level.
To change the job execution order
A sub menu appears.
Moves the job one level up. If you want to move ahead more than one job, click this menu item till you reach the position.
Moves the job one level down. If you want to move down more than one job, click this menu item till you reach the position.
Moves the job to the first position.
Moves the job to the last position.
Moves the job to the specified position. You can use this option for example, when you want to move ahead or below of more than 5 jobs.
Clears the existing order of the jobs and reorders them alphabetically.
The jobs are reordered based on the selected menu item.
