Asset management integrates with CA Service Desk Manager for automatically raising service tickets when an asset violates a policy. To configure this integration to Service Desk, follow these steps:
The right pane displays the policy settings relating to service desk integration.
Note: You can change these values only if you unseal the Default Configuration Policy by right-clicking the policy and selecting Un-Seal.
Indicates whether CA Service Desk Manager integration is enabled.
Default: False
Defines a reserved field in MDB for querying all tickets being created by a specified asset or software distribution.
Note: Instead of the default, you may want to reserve one of the string# fields that CA Service Desk Manager provides for user-specific purposes.
Default: summary
Specifies the logon password for CA Service Desk Manager Web Services.
Specifies the name of the policy to log into if Type of Logon to Service Desk is set to notmanaged. If left blank, the default Service Desk policy is used.
Note: A PKCS#12 certificate includes a policy description that will always override this value.
Default: MANAGED_ASSET_EVENTS
Defines the user account for the logon to CA Service Desk Manager Web Services.
Default: System_MA_User
Specifies the URL to CA Service Desk Manager Web Services. Replace myhost with the appropriate server address for your installation. Note that port 8080 is the default port.
Default: http//myhost:8080/axis/services/USD_R11_WebService.
Indicates whether networking and CPU throttling are enabled.
Default: False
Specifies the timeout interval for calls to CA Service Desk Manager Web Services. Valid values are: 0 = infinite, positive integers = seconds, and negative integers = milliseconds.
Example: A value of 200 means a call will time out after 200 seconds, but a value of -200 means it will time out after 200 milliseconds.
Default: 120
Indicates how logon to CA Service Desk Manager Web Services is controlled. Valid values are: managed (by PKCS#12 certificate) and notmanaged (by user account and password).
Default: managed
The integration to the Service Desk is configured as per the settings specified in the above fields.
Note: You must restart the DSM Explorer GUI for the integration to take effect.
Important! This section is intended for the administrators only. Entering incorrect information may result in the product not working properly. Hence, it is recommended that you create a new policy and modify the same.
