The default Inventory Configuration collect task collects the general and performance inventories. If you want to collect additional inventory or restrict the inventory collected by the default collect task for a particular group or asset, you can create a new collect task, configure the required modules, and schedule the task on the assets or groups.
To create, configure, and schedule a hardware inventory collect task
The Select New Collect Task Type dialog appears.
The Schedule new Collect Task dialog appears.
The Scheduling Options dialog appears.
The Scheduling Options dialog closes and the Schedule new Collect Task dialog appears.
The collect task is configured with the selected modules.
Note: For more information about what each inventory detection module collects, see the Asset Management section of the DSM Explorer Help.
