The optional description statement gives more information about the element being defined. It provides a description of the element and displays it to the users. A sample of the syntax is:
description = "description string"
In the description statement, the .MIF file provider defines the description string. However, users can edit the .MIF file and change the description. The description statement is used in the component, group, and attribute definitions. The description statement can appear only once per definition.
