The keywords "start" and "end" delimit the scope of a definition block. An associated keyword must follow both start and end. The keywords and their scope are listed in the following table:
Block |
Within |
Description |
Component |
.MIF file |
Defines a component. All other blocks exist within this scope. There can be only one component definition per .MIF file. |
Path |
Component |
Associates a symbolic string with operating system specific path names. Zero or more path definitions may exist in the MIF, usually at the top of the file before any groups. |
Group |
Component |
Defines a collection of attributes, sometimes used as a template row for a table. At least one group is required per .MIF file (the ComponentID group, defined following). |
Attribute |
Group |
Defines a unit of managed data. All attributes "exist" in the scope of a group definition. A group must contain at least one attribute. |
Table |
Component |
Defines one or more instances of a group using a previously defined group. Optional. |
Enum |
Component or Attribute |
Defines a list of integer-to-string mappings. Named enumerations can be defined at the component level, while unnamed enumerations can be defined in the scope of an attribute definition. Optional, but while many enum definitions can exist at the component level, only one can be defined per attribute. |
Following is an example of a .MIF file structure. For readability, only one of each block is given. Each level is indented for readability:
start component
start path
end path
start enum
end enum
start group
start attribute
start enum
end enum
end attribute
end group
start table
end table
end component
