When a remote agent is installed in CA Client Automation, it is registered as a new agent component named AM remote agent, which represents the collecting entity. The AM remote agent appears in the Agent components list when viewing the agent properties of a computer.
Note: The AM virtual agent (AMVirtualAgent) now represents the collected entity in this release. The AM virtual agent serves to indicate that the virtual host contains no real agents, but rather only a virtual agent.
You can create a custom computer query based on agent components to view all remote agents. The query results list all agents that have the AM remote agent installed.
The Select Target dialog appears.
The Query Designer dialog appears.
The Select Field dialog appears.
You are returned to the Query Designer.
The results are displayed in the Query Preview pane.
The Save Query dialog appears.
The query is created with the specified name and added to the Queries, Computers subfolder.
You are taken to the agent node under All Computers where you can opt to configure the agent for remote virtual host inventory collection.
