You can create a query when you need to get a list of assets that meet certain criteria. You can use these queries to create dynamic groups and query-based policies.
To create a new query
The Select Target dialog appears.
The Query Designer dialog appears.
The query is created with the given name and displayed under the appropriate folder in the Queries folder.
Example: Create a Query to display all the assets that have completed the Check C: drive using default option job Successfully.
The Select Field dialog appears.
The new query is created under the Queries, Computers folder.
All the assets that have successfully completed the Check C: drive using default option job appear.
