Previous Topic: Results Reported by the ScannerNext Topic: Queries and Reports
View Scan Results
You can view the scan results to see if an agent computer passed or failed the compliance check. The results display against each rule in the XCCDF file. The DSM Explorer and the Web Console present the scan results in an easy-to-read format. You can also open the XCCDF and OVAL test result files to view the results of the scan.
To view the scan results from the result files
Navigate to the following directory to view the XCCDF and OVAL test result files:
To view the scan results from the GUI
  1. Navigate to Computers and Users, All Computers, Computer Name, Inventory, SCAP, Inventory Component Name.
    Note: Inventory Component Name is the value you specified for the Inventory Node Name field in the SCAP Configuration dialog when you created the inventory detection module.
    The scan results for the selected inventory component are displayed in various sub-nodes. For more information about the scan results, see the DSM Explorer Help.
