If you are using Open Workbench with CA Clarity PPM, you can create multiple baselines to track the progress of your projects from:
Note: The project must be unlocked to create a new baseline.
Baseline data is stored at the summary-task and project level. Cost data is stored with the baseline. If you make subsequent changes to rates, they do not retroactively modify baseline costs.
If you are using Open Workbench with CA Clarity PPM and you rebaseline the master project, only the data you enter directly in the master project is captured and not the data you enter in the subprojects.
From Open Workbench you can:
To save a baseline in CA Clarity PPM, you must have the access rights to modify baselines for the project.
Note: See the Project Management User Guide for more information.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
