If you are using Open Workbench with CA Clarity PPM, you can hold a lock when saving a project by saving it as a new project. You can also hold a lock by closing the project without saving it to CA Clarity PPM, and saving it locally as an Open Workbench file.
You can close the project and hold the lock using the Save As dialog box. The name of the CA Clarity PPM server that hosts the project displays in the CA Clarity PPM Host field.
To close the project and hold the lock
The Save As dialog box opens.
Defines the type of file you want to save the project.
Values:
Select Workbench Files (*.rmp).
Specifies whether or not to hold the lock or unlock the project when saving it to your computer or network.
Note: This check box is displayed when you choose Open Workbench or XML from the Save Type As drop-down.
Select this box.
The Save As dialog box closes.
The project closes without saving changes to CA Clarity PPM.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
