Open Projects from CA Clarity PPM
You can open any active projects you have rights to view or edit from CA Clarity PPM. To open projects from CA Clarity PPM, they must be formatted in Microsoft Project.
You can open projects formatted in Open Workbench from the CA Clarity PPM Schedule Connect.
If you can view or edit a project, you can choose to open the project as read-only or read/write. If you only can view a project or if the project is currently locked, you can open the project as read-only.
Note: You cannot open projects with the same project ID and .MPP file name in Microsoft Project from different CA Clarity PPM servers on your computer. If you must open a project under these conditions, delete the .MPP file saved locally and then try to open the project with the duplicate project ID from the other CA Clarity PPM servers.
When you open a project from CA Clarity PPM, the following occurs:
  1. In CA Clarity PPM, go to the Projects page and click the name of the project you want to open.
    The Project Overview page displays.
    Note: See the Project Management User Guide for more information.
  2. Ensure the project is formatted in Microsoft Project.
    Note: If the Scheduler Format field is not displayed, contact your CA Clarity PPM administrator for assistance.
  3. Select one of the following:
  4. Click Go. The project opens in Microsoft Project.
    Tasks created with dates set in CA Clarity PPM that are different than the project start date acquire Start No Earlier constraints to hold them there. Work effort estimates for each role on each task are loaded into Microsoft Project including the distribution of this work over time.
More information:
Open CA Clarity PPM Projects from Microsoft Project
Microsoft Project Field Mappings
