If you are using Open Workbench with CA Clarity PPM, you must specify that you want the Log on to CA Clarity PPM dialog box to open each time you start Open Workbench. This dialog box allows you to specify whether or not you want to log on to CA Clarity PPM during an Open Workbench session.
To set the option to be prompted to log on to the CA Clarity PPM server each time you start an Open Workbench session
The General tab on the Options dialog box opens.
Specifies whether you will be prompted to log on the CA Clarity PPM each time you start Open Workbench.
Default: Cleared
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
