Completely Uninstall the CA Clarity PPM Microsoft Project Interface from Microsoft Project
To uninstall CA Clarity PPM Microsoft Project Interface completely from Microsoft Project, you need to remove CA Clarity PPM-specific macros and the CA Clarity PPM Integration toolbar or menu from Microsoft Project.
Note: When upgrading, it is not necessary to completely uninstall CA Clarity PPM Microsoft Project Interface.
To completely uninstall CA Clarity PPM Microsoft Project Interface from Microsoft Project
  1. In Microsoft Project, open the Visual Basic Editor and navigate to ProjectGlobal (Global.MPT) > Microsoft Project Objects > ThisProject, and double-click ThisProject (Global.mpt).
    The Global.MPT window opens in the right pane.
  2. Close the Visual Basic Editor and return to Microsoft Project.
    The Visual Basic Editor closes.
  3. Select Tools, Organizer, and click the Modules tab.
    The Modules tab appears.
  4. Select and delete all of the modules that start with Niku.
  5. Click the Toolbars tab.
    The Toolbars tab appears.
  6. Select and delete the CA Clarity PPM Integration toolbar.
    1. If you have chosen to set up the CA Clarity PPM Integration as a menu, right-click the CA Clarity PPM Integration menu, and select Customize.
      The Toolbars tab on the Customize dialog box opens.
    2. Select the Menu Bar check box and click Reset.
      The changes made to the Menu Bar toolbar are reset.
