Previous Topic: Automatically Start During InitializationNext Topic: Stop CA Chorus for Security and Compliance Management Components
Start with a Console Command
If you did not yet start the CIA real-time component, use a console command to manually start the CIA real-time component.
To manually start the CIA real-time component, issue the following command at the console:
S CIARTUPD
Note: If you changed the name of the CIA real-time component procedure, specify that value in the command rather than CIARTUPD.
How to Stop CA Chorus
You can stop the CA Chorus components independent of the back-end products supporting each discipline. For example, CA Database Management for DB2 for z/OS products that are used with CA Chorus for DB2 Database Management. When the CA Chorus components are down, the back-end products continue to operate in your environment.
