Use the installation worksheet to record server names and credentials that are used with the solution that you provide to the installation program. Create a deployment worksheet similar to the one provided here. You need this information when deploying the solution.
Software |
Details Needed |
Your Notes |
Microsoft SQL Server |
Host Names |
Instance Name |
Oracle Java SDK/JRE |
CA Process Automation |
Tenant Credentials |
Agent Port |
Default:7003 |
CA Service Catalog |
Server Credentials |
Admin username and password |
For all the servers that are used in this solution. Use these credentials to perform relevant tasks. |
Content pack folder path |
%USM_HOME%\filestore\contentpacks\
foldername where %USM_HOME% is the home directory where CA Service Catalog is installed. |
