The first step in enabling IP addresses at your site is defining network address pools in the main user interface of the product. Network address pools consist of a range of IP addresses.
Note: Reservation Manager does not permit editing or deleting a network address pool that has been used for reservations. If you want to change something like the IP address range, make a new network address pool. Also, deleting a network that is associated with a VM or logical partition is not allowed.
The Data Center page opens.
The Manage Networks page opens.
A new page for entering network information appears.
A dialog for IP address ranges appears.
Note: Each address in the pool must have a DNS name entry when the pool is created. When you define network address pools, verify that the static IP address ranges are not assigned to another type of data center.
The Virtual Hosts pane opens.
Each virtual host must be associated with the network before IP addresses can be assigned to VMs created on the host.
The network address pool is created and visible on the Reservation Manager page.
