You can select one or more datastores and can submit the request to deprovision. If the selected datastore is in use, the deprovisioning request is canceled and you receive an email notification.
The Infrastructure Management page opens.
A list of datastores that are provisioned to the user opens.
A confirmation message appears indicating that your request was submitted successfully.
The Service Administrator modifies the pool manually by removing the datastore from the pool and changes the request status to Datastore detached from Pool.
The request is processed to remove the datastore from the ESX Host or Cluster, and the dataset is deleted from the storage server.
The selected datastore is removed.
