Using the Report Builder, you can view the following reports for chargeback:
This report provides information about the server costs by cost center per annum. The report details about the reservations that are made by Service Consumers for their cost center and the costs that are incurred for each reservation.
This report provides information about the reservations that are made through a cost center in a particular month.
This report provides information about the reservations that are newly added and returned in a particular month.
As an example, this procedure describes how you can generate the Get VM Reservations By Cost Center report. For more information on the report builder, see CA Service Catalog Administration Guide.
Note: Before you generate a report, generate an invoice-on-demand. Then, complete the following procedure to view the report.
The Report Builder page appears, with Data Objects selected in the left menu under the main menu.
The list of existing data view folders appears.
A pop-up appears to enter parameters.
The VM Reservations By Cost Center report opens in a new page.
Repeat the procedure and provide the parameters at step 6 for the other available reports to generate them.
