Now that you have successfully published the service, a service consumer can go the folder that is used during publishing of the service and begin to consume the published services.
For example, assume that you have created a service with the name Test VM Template, using the Service Offering Using VM Template under the Catalog Services folder. Now your Service Consumer can create a new reservation.
The services page lists the Test VM Template.
The reservation form opens.
Note: Contact your Service Provider, if you need to change the image displayed in the form.
Specifies the name for the reservation.
Specifies the date and time required for the reservation. You can specify the starting and ending date and time.
Specifies the name of the cost center.
Specifies the name of the department.
Specifies the number of virtual machines.
Specifies the size of additional disks required.
Specifies the names of secondary users who can manage the reservation and can have administrative access to the virtual machines.
After you check out, the recurring cost of the reservation for the period selected is displayed as follows:
You get email notification after the reservation request gets approved and completed.
