Previous Topic: Chargeback ServicesNext Topic: Create a Chargeback Service Offering Using Reservation Template
Create a Chargeback Service Offering Using VM Template
The following procedure describes how you create a service offering using VM template and later the Service Consumer can consumer this service.
  1. Log in to CA Service Catalog.
  2. Click Request, CA Automation Suite for Clouds.
  3. Click Server Automation Services.
    The Server Automation Services page opens.
  4. Click Chargeback under VMware ESX Management.
    A list of all chargeback services appears.
  5. Click Service Offering Using VM Template.
    A form opens.
  6. Complete the following information to create a service offering:
    Service Details
    Specifies the details of the service.
    Name
    Specifies a name for the service.
    Description
    Specifies the description of the service.
    Icon
    Specifies an image to the service. Click Select Image to select the image from the %USM_HOME%\filestore\images\offerings folder.
    Folder
    Specifies the location where the published service appears.
    Service Packages
    Select the organization name from the drop-down menu, click + to add a new row to provide package details. You can specify the cost of components and can save the details. If you have more than one package to be associated with the current service then each package will be represented as independent service option group after you publish the service. To add more packages click + again and complete the required information.
    Package Details Screenshot for Service Offering Using VM Template
    Complete the following to add a package:
    Name
    Specifies a name for the package. Type a name for the package.
    Description
    Specifies a description for the package name.
    Template
    Specifies the SSRM VM template to use.
    Resource Pool
    Specifies the name of resource pool to be used for VM provisioning.
    Base Cost
    Specifies the cost for the reservation.
    CPUs
    Specifies the number of CPUs for the reservation.
    Memory (GB)
    Specifies the memory size in GB.
    Storage (GB)
    Specifies the predefined size of primary storage in GB.
    Storage Cost (Per GB)
    Specifies the cost for 1 GB of storage space.
    Note: Optionally, to delete an item from the package details list, select, and click Remove.
    Permissions
    Select the user groups to grant access to the service. You can search for the group name and then add the required groups to the list.
    Note: Before you submit the request, make sure that you select all the required package items from the list.
    7. Click Check Out.
    You have enabled your Service Consumer to request a new reservation using the new service offering.
