Verify that the LinuxAdmin VM parameters in the ASC_Globaldataset for the VMware ESX cartridge are configured.
Specifies the Linux VM template parameters.
For each Linux VM Template, verify the following LinuxAdmin parameters:
Specifies the name of the Linux virtual machine template.
Specifies the user name of the virtual machine that accesses the newly provisioned Linux VM using the template.
Default: root
Specifies the administrator password.
Specifies the port where SSH service is listening on the newly provisioned Linux virtual machine with the template.
Default: 22
Specify true if you want to use the sudo user in the Linux environment. For information about configuring the sudo user, see the Update the sudoers File section.
You have enabled the support for primary disk extension.
