Previous Topic: Apache Tomcat Installation ConsiderationsNext Topic: Coexist with Previous Versions of Apache Tomcat
Upgrade Previous Versions of Tomcat
If you choose to upgrade to Apache Tomcat version 6.0, which is distributed with CA Automation Point Service Pack 11.3.03, and you are not using the old version of Apache Tomcat to power other applications, we recommend that you uninstall the old version of Apache Tomcat first. Apache Tomcat version 6.0 installation process does not automatically uninsall a previous version.
To uninstall Apache Tomcat and upgrade to the latest version
  1. From the Windows Control Panel, select Administrative Tools, Services.
    The Services list appears.
  2. Select Apache Tomcat from the list and click Stop the service.
  3. From the Windows Control Panel, uninstall the previous version of Apache Tomcat.
  4. In Configuration Manager, navigate to Expert Interface, Notification Services, Notification Manager, NM Web Services.
    The NM Web Services Dialog appears.
  5. Clear the Enable access to the notification website check box.
  6. Click Install Tomcat.
  7. After Apache Tomcat 6.0 installs, on the NM Web Services Dialog, check Enable access to the notification website.
  8. Check Use local Java Servlet environment.
