Previous Topic: Known IssuesNext Topic: MDB Cell Error During Installation of CA Common Services
Session Definition Sets
If you have multiple session definition sets and have applied the event monitoring settings to only a subset of these session definition sets, and then you activate one of the session definition sets to which event monitoring settings were not applied, you will not see the sessions associated with the monitored event when CA Automation Point is started. However, when you go into the particular event monitoring dialog, all settings will appear enabled.
