If you have installed an earlier version of the Java Runtime Environment (JRE) or an earlier version of the Java Development Kit (JDK) for use with an earlier release of CA Automation Point, you can uninstall either or both, then install the JRE distributed with CA Automation Point Service Pack 11.3.03. To run Apache Tomcat 6.0 (distributed with CA Automation Point Service Pack 11.3.03), you must have JRE version 1.6 or later. JRE version 1.6.0 is redistributed by CA with CA Automation Point Service Pack 11.3.03.
