Previous Topic: MDB Cell Error During Installation of CA Common ServicesNext Topic: CA Automation Point and CA MICS Q&R Workstation
Open File Dialog during Installation
In rare cases, a generic Open File dialog appears during the installation process requesting a file with an .exe extension. This happens under some circumstances when CA Secure Socket Adapter is installed on the system (usually as part of another CA product).
You can close the Open File dialog by clicking Cancel on the dialog; the CA Automation Point setup should finish successfully. The only side effect of this issue is that the Windows Add/Remove facility will now contain two separate entries for CA Secure Socket Adapter. This has no impact on the runtime operations of CA Automation Point. If you want to remove the obsolete entry, contact CA Technical Support for further assistance.
