Previous Topic: Interaction with UACNext Topic: Known Issues
Optional Interface Components
When installing any of the optional Interface components (CA OPS/MVS EMA, CA NSM Event Manager, or CA NSM WorldView), make sure that a network connection is available on that computer. If there is no network connection, the installation of some or all of the interface components may fail.
Note: This does not impact the setup of the CA Automation Point Server or Client components.
Published Fixes
The following is a list of fixes made for CA Automation Point Service Pack 11.3.03:
ATMXC 659
Fixes a problem that occurred on non automated consoles where the cursor was being forced to the next writable field. This problem was causing the cursor to jump to the command area as the operator was attempting to move it.
ATMXC 661
Fixes a problem that was causing the "AXC0043W Session sessname will not be started because it is configured with a 3251_CFE terminal type which is no longer supported" message to appear.
ATMXC 662
Fixes a problem that occurred when issuing an ADDRESS OPS command processor with CmdResp(XDQ) specified. This problem caused the return data from the REXX program to not be saved to the External Data Queue (XDQ).
ATMXC 664
Fixes a problem that caused the IMPORT SESSION dialog to fail to copy fingerprints for SSH sessions.
ATMXC 665
Fixes problems the CA OPS/MVS Interface incurred while establishing remote connections in CA Automation Point 11.3.
ATMXC 666
Fixes the problem APCMOS was having to query or set attributes that are part of activation profile groups.
ATMXC 667
Messages generated from ADDRESS GLV commands that internally call the functions VarGet, var_get, VarSet, var_set, VarList, and VarPurge have been reclassified from informational to trace.
ATMXC 668
Fixes TN3270 sessions from displaying an empty gray field.
ATMXC 670
Fixes the CMDTEST.EXE utility. This utility did not work correctly when an output from a tested command contained a delimiter (in this case the % sign).
ATMXC 671
Support for the REXX command environment on AP client workstations was dropped in CA Automation Point 11.3. To mitigate the impact on the automation in place, this fix adds support for AP client workstations to play .WAV files through the APSpeak client component.
ATMXC 672
Fixes a problem with the NM Gateway failing to start with a 1062 (Access Denied) error.
ATMXC 673
Fixes a problem with the ADDRESS AXC SESSCMD command reporting errors from timeout or the non issue of a command when the consoles are working properly.
ATMXC 674
ATMXC 675
Fixes the problem with Manage Site Files GUI hang.
ATMXC 676
Fixes the problem with the Manage Site Files utility failing with the error message "Cannot find the path specified" when the Export directory did not exist under the user data path.
ATMXC 678
Fixes a problem that occurred when upgrading from a CA Automation Point 11.2 client installation. This problem occurred when the backup and CA Automation Point 11.3 data migration that was performed by the ExpImpCfg failed. This failure occurred when the Site\Config directory did not exist.
ATMXC 679
Fixes a problem with previous versions of CA Automation Point being listed in Windows Control Panel, Add or Remove Programs as being installed concurrently with CA Automation Point 11.3. This problem could have occurred if CA Automation Point 11.1 or 11.2 were improperly uninstalled.
ATMXC 680
Fixes a problem with Autostart Manager not starting the Automation Point Desktop.
ATMXC 681
Fixes a problem with only four voice channels being available in the Configuration Manager NM Voice Groups Dialog when there are more channels on the Dialogic voice card available.
ATMXC 682
Fixes a handle leak in the TN3270 reconnect logic.
ATMXC 683
Fixes a problem with incorrect initial privileges when creating a notification manager login.
ATMXC 684
Fixes the defining a scheduling time block for the notification manager problem. This problem had a begin time that designated any time between 12.01AM and 12.59AM and end time that designated between 1:00AM and 11:59AM on the same day.
ATMXC 685
Fixes a problem with exception in voicesrv.exe – uidlSMTP.dll
ATMXC 686
Fixes a failure if Windows Event Log is monitored on Windows 2008.
ATMXC 687
Fixes a problem when connecting to an Automation Point server from an earlier apView client (11.1 or 11.2) – the client paints a partial screen.
ATMXC 688
Fixes a problem with notification status when a SYSTEM parameter is specified for a PAGE2WAY notification method.
ATMXC 689
Fixes a problem with frequency of calling NMIANSWER command during PAGE2WAY notification.
ATMXC 690
Fixes an issue when the name of ASYNCH SESSION contains leading or trailing spaces.
ATMXC 691
Fixes a problem when REXX LOGGING is enabled and output from REXX script contains unprintable characters.
ATMXC 692
When there is a HEARTBEAT = YES parameter on the remote statement in the CCIRMTD.rc file on Windows that is provided for connectivity problems.
ATMXC 694
Added the possibility to switch between 12/24 time format (new item in Options menu).
ATMXC 695
If a message used by the EXPORTMSG feature contains unmatched brackets, this wrong message is excluded from processing and the feature is not disabled.
ATMXC 696
A fix was written to expand the memory pools available to the GLV operations.
ATMXC 697
Fixed the heap corruption problem, with not enough memory allocated for OPS PPQWRITE.
ATMXC 698
In the 5250 inbound data stream EBCDIC 1F is printed on the display as space items.
ATMXC 699
To use a longer SMTP header with Sendmail and Notification Manager, appropriate change was determined upon test fix impact resolution and testing.
ATMXC 700
Incorrect registry parameter causing an error during install of the remote viewer was fixed.
ATMXC 701
Fixed notification of certain contacts in the tree, that ware blocked.
ATMXC 702
Fixed recognition of multi-line SMTP banners to be processed.
ATMXC 703
Fixed problems with 3270 sessions sometimes not connecting because of deadlocks introduced during last version improvements.
