Previous Topic: Dropped Support of Third-party SoftwareNext Topic: CA AP Autostart Manager Service
Multiple Instances of Java Required on 64-bit Systems
If you choose to enable access to a local Notification Website on a 64-bit version of the Microsoft Windows Server operating system, you must install both the 32-bit version of the Java Runtime Environment (JRE) and the 64-bit version of the JRE. Both versions of the JRE are distributed by CA, so you should not need to download these components separately. The 32-bit version of the JRE is required to run the NM Web Gateway service, and the 64-bit version of the JRE is required for the Apache Tomcat server distributed by CA. The NM Web Services dialog in the Configuration Manager application requires that both versions of the JRE be installed before a local Notification Website can be configured.
