Previous Topic: CA NSM SecurityNext Topic: CA Automation Point Client Installation
Site Files Relocation
With this release, CA Automation Point supports running on Windows Server 2008. As part of this support, the Site files directory can be installed into its own directory, independent of where CA Automation Point is installed. This change was made because Windows Server 2008 does not allow programs running as a Standard User to create or modify files under the default installation location in the Program Files directory. Windows Server 2008 uses a new directory, ProgramData, for this purpose. When you install this release of CA Automation Point on a Windows Server 2008 machine, you will be prompted to supply a location for UserData. The default for this UserData directory path is %ALLUSERPROFILE%\CA\CA Automation Point.
For more information about the Site Files directory, see the Installation Guide and the Administration Guide.
