Reason:
The stem variable specified by varname does not contain a valid count integer.
Action:
Verify that the stem variable used for command input is properly set up with the varname.0 element containing an integer count of lines, and that the elements varname.1 through varname.n are set (where n is the value placed in varname.0).
Copyright © 2012 CA.
