Reason:
The specified REXX variable is not set.
Action:
Verify that the variable specified by the VAR operand on the command is set. If the command did not contain a VAR clause, locate the file ASOTRACE.LOG, then contact CA Technical Support.
Copyright © 2012 CA.
